01-09-2020
06:03
10:12
DavideFitbit
01-09-2020
06:03
10:12
DavideFitbit
I have a Versa 2. I have downloaded 5 clock faces, but now would like to change one of them. Is it possible to delete clock faces once downloaded? If so how?
01-09-2020 08:06 - edited 01-09-2020 08:07
Hi @NanaBruens , go to the Clocks Tile and press it. On the bottom of "My clock" you will see all your installed Clocks. Press and hold the one you want to remove untill a popup shows up with the "Remove this clock" option and press remove. Regards kuzibri
Best Answer01-12-2020 00:08
01-12-2020 00:08
@SunsetRunner: In the App or on the Watch?
In my case, I already removed it from the app but it’ still on the watch! And when I press and hold on the watch, the only thing happening is the face becomes the current face
Best Answer01-12-2020 06:05
01-12-2020 06:05
Hi, in the App, regards kuzibri
