02-03-2023 00:20
02-03-2023 00:20
Hi there
My versa 3, bought October 21. 15 months old. Worked perfectly until this week.
The device gets warm when I plug in, logo appears, single line flashes on screen. Won't go any further with start.
Won't charge, have tried:
02-03-2023 01:34
02-03-2023 01:34
Hi @IsabellNecessar I5 does sound as if your Versa 3 has died. I would not say this is normal, but it happens. Contact Fitbit Support and hope they can help.
Helen | Western Australia
02-03-2023 01:34
02-03-2023 01:34
02-03-2023 04:00
02-03-2023 04:00
So I had a very similar experience with mine; similar age Versa 3. Fitbit support suggested a 20second hold to reset and it miraculously sprang back to life. Hope yours is so easily fixed
02-03-2023 16:50
02-03-2023 16:50
Thank you... sadly I have tried everything and nothing is working...all the resets, all the holds and nothing .
Appreciate the advice. Thank you
