Hi all! Is anyone else having major issues with their Versa battery, more specifically after this latest update? I noticed a couple of weeks ago it seemed my battery was draining more quickly then it used to so I came and found an article here regarding similar issues and followed every single step but it did not help. When I was alerted that my Fitbit needed to update I did so and was hopeful that maybe that was the reason for the battery issues and it would fix itself but it had gotten way worse. I charged my Fitbit last night to 100% right before bed and then put it on. When I woke up this morning around 7 am my battery was at 58%, just after sleeping, that is RIDICULOUS! I am extremely disappointed as I have only had this Fitbit since September (of 2019), it was actually a gift from my husband because I have started running and training for 5ks and such. My battery used to last almost 5 days when I first got it and the settings that I had set up when I first got it are the exact same setting ls that are on it now. Nothing has changed with my usage of it either, I have no third party apps, music, nothing on it. I strictly use it for running only, so there is no way it has anything do with settings, music, notifications, brightness, etc mentioned in other articles because again, I have changed nothing since the day I got it, except this latest update. Any help would be greatly appreciated because you can’t tell me that within 2 months my Fitbit has pretty much died. Thanks in advance to anyone who can help!
Hi @Thewatsons14 , restart your Versa three times in a row (internal rest) by pressing and holding the left and right lower buttons together untill you see the Fitbit logo and release the buttons. If that does not solve your problem, which I expect it won't, call Customer Support and ask for a battery test. Why the three reset? This will be the first question you'll get form CS when you call them. Regards kuzibri
Best AnswerThanks I have tried this several times already with no luck but I will try once more and then contact them! Thank you!
