10-07-2022
08:00
17:09
10-07-2022
08:00
17:09
I would like to be able to check my heartrate while excercising, and when I'm not wearing my glasses. Is there an app or widget or clock where I can see my heartrate in LARGE numbers? It's not necessary for me to log the excercise in the excercise app, the most important thing is that I can check my heartrate instantly. Does anyone know how to?
Hello @Lefr and welcome to the Community. The middle stat lets you scroll through several real time stats when you are using the Exercise app. Your heart rate is one of the stats. The Versa 3 also lets you customize all three stats. If you can read the middle stat without your glasses, and you don't want to scroll through others, you can set your heart rate to be the only middle stat in that exercise shortcut. Or keep the few that you want and need.
Laurie | Maryland
Best AnswerHello @Lefr and welcome to the Community. The middle stat lets you scroll through several real time stats when you are using the Exercise app. Your heart rate is one of the stats. The Versa 3 also lets you customize all three stats. If you can read the middle stat without your glasses, and you don't want to scroll through others, you can set your heart rate to be the only middle stat in that exercise shortcut. Or keep the few that you want and need.
Laurie | Maryland
