02-23-2019 18:15
02-23-2019 18:15
Leaderboard is not updating. I keep receiving a message “Please allow the internet permission for the app to work”. My husband has the same Fitbit Versa and his is working properly. Anyone else having this issue? I already tried logging out, rebooting phone then logging back in didn’t work.
02-24-2019 05:20
02-24-2019 05:20
Hi there! Thank you for the feedback. I have the iPhone 7. I tried all of the above as you mentioned and nothing worked. I ended up just uninstalling the leaderboard app and reinstalling it, and that seemed to work for me. Thank you though!
02-24-2019 05:12
02-24-2019 05:12
@Misslondon Welcome to the Fitbit Community! It's great to have you here! Sorry to hear that your leaderboard isn't updating and thank you for troubleshooting this issue. Which phone are you using? Is it compatible? If it is an Android then you can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. This will refresh the link between your phone and your Versa. Also, since you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
Let me know how it goes!
02-24-2019 05:20
02-24-2019 05:20
03-22-2019 17:13
03-22-2019 17:13
@Misslondon thank you for your update and sorry for the late reply. Happy to hear that you were able to resolve the issue and thank you for sharing what you did to fix it as it may help other members in the same situation.
I'll be around.
