Hi @caekfar There is probably not much you can do. If the button is stuck by a small piece of grit you can try to remove it with a needle. But if the butt9n presses but nothing happens you will need to try Restarting your Versa. If that doesn't help try a Factory Reset and then set up again. If that still doesn't help then contact Fitbit Support
Helen | Western Australia
