I fully charged the Versa, but the only screen was the logo screen telling you to download the app in several languages. I tried swiping up, down, left, right. Pressed all three buttons. Pressed and held down each button. Still couldn't get it to do anything other than the logo screen. We finally disabled the security setting on our router just long enough for me to do the setup.
Why don't they put the MAC address on the box since almost everyone has some kind of security on their routers now? (Or they should if they don't.) Updating over Bluetooth doesn't seem to work or takes ridiculously long.
Best AnswerMy charge 3 doesn't show me my mac address here?
Best AnswerYou should be able to go into your logs for your router or go to the page where you enter your MAC Addresses for filtering. When the watch starts the update, check these locations and the MAC Adress should appear in the list. My NETGEAR Nighthawk says the name Sense (the watch I have) and shows an IP address and then a MAC Address. I check the box next to the Sense and tap on Allow. It will be different per router, but this should give some guidance. I was able to successfully update my Sense on my network with all new connections blocked even if the SSID and Passcode are entered. After selecting Allow and tapping Apply, all worked great.
