08-07-2019 18:09
08-07-2019 18:09
After a run exercise, my Versa app shows the map of the run. But later, there's now just a spinning circle as if it is trying to load the data but could never complete. How do I fix this. Thank you.
08-08-2019 03:34
08-08-2019 03:34
@hungster An issue like this is usually an app issue, not a device issue. Are you using iOS, Android or Windows? You issue can get moved to the correct forum.
Laurie | Maryland
Best Answer08-08-2019 12:50
08-08-2019 12:50
I am using an Android phone; Moto G5 Plus.
Best Answer08-11-2019 10:54
08-11-2019 10:54
OK, thanks for the advice about incorrect forum. But how do I move the post to Android board? There is no option for me to move it myself?
