05-19-2018 03:45
05-19-2018 03:45
I have had my Versa for only three days, received it Wed evening and I keep getting a message, “To continue using Cockpit please visit kzl.io/code and enter this code,” it then lists a code number which changes every time it shows up on my screen. I can’t make it go away?
Best Answer05-19-2018 05:10
05-19-2018 05:10
You're using a paid clock face whose trial has expired. This is why this is showing up. In order to make it go away, choose a different clock face in the clock section that is free.
05-19-2018 05:10
05-19-2018 05:10
05-19-2018 05:43
05-19-2018 05:43
Best Answer05-19-2018 06:14 - edited 05-19-2018 06:15
You're very welcome. The information about each watch face is in their description once highlighted at the very bottom if they are paid or free.
05-19-2018 07:31 - edited 06-28-2021 23:36
If you really like the app or clock face.. go to the page link in the tracker. Here you will enter the code and use a card or PayPal to pay. Usually only a dollar or two.
Within a second the notice will disappear.
Best Answer02-22-2020 01:44
02-22-2020 01:44
Beauty!☆
Best Answer06-28-2020 12:15
06-28-2020 12:15
Even after I paid the 99 cents for the clock gave the kzl.io/code is still on my fit bit...
Best Answer06-28-2020 12:17
06-28-2020 12:17
I figured it out. I just did a hard shut off of the fit bit. Thank you
Best Answer10-11-2020 17:24
06-28-2021 21:04
06-28-2021 21:04
Thank you for the quick info. I did not know this about the clock.
