I have problems with Facebook messenger notifications on my Fitbit Versa.
The problems just occurres now and then which is very annoying.
For example, yesterday notifications worked just fine. But today I won’t get any notifications from messenger. Other notifications such as incoming calls works.
I wonder what I can do to fix this though it’s very annoying.
I’ve tried to restart my device without solving the problem.
This can explain the problems you have with Facebook notifications. It's known that FB and Whatsapp on iOS reacts differently than on Android. AFAIK, there is still no solution for this. You can try to restart you iPhone and see if that solved the problem.
Best AnswerThis can explain the problems you have with Facebook notifications. It's known that FB and Whatsapp on iOS reacts differently than on Android. AFAIK, there is still no solution for this. You can try to restart you iPhone and see if that solved the problem.
