06-22-2022
01:27
11:36
AndreaFitbit
06-22-2022
01:27
11:36
AndreaFitbit
I’ve misplaced my Versa 2 and I’m wondering if there is a way to track it
thanks
Hello @carolineW23 and welcome to the Community. If your Versa 2 is connected to your your phone, then it is close by and you can try a Bluetooth finder app. They are available in the App Store or Google Play Store. I never used one, so I don't have a preference. If your Versa 2 isn't connected, then you will need to retrace your steps and keep searching.
Laurie | Maryland
11:39
10:47
06-22-2022
11:39
10:47
Welcome to the Fitbit Community, @carolineW23 and thank you for your assistance @LZeeW. I'm sorry to hear you lost your Versa 2.
Since you lost your Fitbit device, try the tips below to find it:
Check the Fitbit app to see the last time your device synced. If it synced recently, it's likely within range of your phone.
Take your phone to the area where you think you lost your device and try to sync. If your device syncs, it's nearby.
Try using a Bluetooth locator app to help you find your device. For iPhone, try LightBlue Explorer. For Android, try Bluetooth Finder.
I noticed that you recently synced your device so it should be close.
Keep on visiting the forums.
Hi @carolineW23 - if you have a dog see if it can find it. They love looking for things and are good at it, especially if trained.
