Does anyone know if the Versa 2 is compatible with the Moto G8 Plus? It isn't on the compatibility list but I am just wondering if anyone has tried it?
If not, Fitbit, do you know when this will be compatible?
Thanks
Hi @DafidMedlock , nobody knows when you MD will be compatible with Fitbit, except the tech team. In the mean time, you can install the Fitbit app on your Windows 10 PC and let Windows recognize your MD as a BT device. Once recognized, you can install your MD on your Windows PC and sync it. The only limitations are that you cannot change Clock Faces or install Apps, for the rest it works like it should. Regards kuzibri
