12-17-2018 08:47
12-17-2018 08:47
I have selected various different clock faces that feature a temperature reading as seeing the current temperature at a glance is important to me. Some days they work and other days there is nothing I can seem to do to make them work! I have contacted the various developers and they all suggest I sync my Versa and then swipe up and then go back to the face. Still does not work. This is frustrating. Even my husbands old Samsung Gear show the weather on the face with no problem. I have checked Bluetooth, wireless connection, etc. and nothing seems to work. Can someone please recommend the appropriate settings I need to check so I can get this to work consistently? Thank you.
12-17-2018 09:27
12-17-2018 09:27
Hi, regarding problems with Clock Faces, see: https://community.fitbit.com/t5/Versa/Clock-Faces-can-cause-a-lot-of-Problems-which-are-not-Versa-re... .
Best Answer12-17-2018 09:43
12-17-2018 09:43
Best Answer12-17-2018 09:50
12-17-2018 09:50
Hi, regarding this: "And I don’t get why some developed faces work for most and not for others.", I think that there are two reasons for this:
1. Bugs in the software of the Clock Face
2. Not everyone mentions their problems withj Clock Faces in this community or are no member of it.
