08-17-2019 22:55
08-17-2019 22:55
Hi all,
I'm having a few issues with my Versa, which I have already asked to official Support but they replied with generic and probably automated messages, so basically not even reading my mail and making the assumption I'm a dumbass not being able to try the usual stuff myself. Maybe the community can help me out with my problems. Here goes:
Problem 1) My Versa often stops recording after 1K of running, it started somewhere last winter, at first I thought it was the cuff of my sweater somehow pressing buttons or something. But it keeps happening at random sessions. I've tried different settings and have been double checking I did not forget to press start. All seems okay every time.
Problem 2) As of late my Versa had huge battery drain issues, even when not using the GPS/Bluetooth/Wifi of which I know use a lot of battery. I've removed all third party apps and unused Fitbit apps to be sure. According to Fitbit, the times I sync affect battery life, which I already knew and figured out myself, but these battery problems started suddenly and my syncing behavior did not change. I can basically say all standard solutions supplied by Fitbit do not apply to me.
Any help or suggestions would be much appreciated.
08-18-2019 03:56
08-18-2019 03:56
I can't actually help you, but wanted to validate your battery issue. Mine had been doing the same, in recent months, and I did everything you did to try fixing it myself. I put mine on to charge last night before bed and it didn't charge.
