If you are away from your home, can you use your Versa 2 to trigger any of your routines as long as you have your phone with you? Also, to use Alexa, can you close out the Alexa app on your Android phone, and have the screen locked and display off?
Hello there @Den_in_USA, welcome to the Community Forums. I'm sorry for the late response. I'll be glad to help you.
About using your Versa 2 when you're away from home (I guess you will be traveling?), most trackers store up to 7 days of detailed minute-by-minute data. If you wait longer than 7 days before syncing, you may only see the most recent week's detailed data.
Summary data (calories, distance, steps, and floors) will be stored for 30 days. If your tracker measures heart rate, summary heart rate data will be stored as well. For more information about the syncing process, see: How do Fitbit devices sync their data?
To get all the information about Alexa, I'd recommend taking a look at the article: How do I use Alexa on my Fitbit Versa 2?
I'll be around if there's anything else I may do to help you.
