My Clock Faces!?
Woke up this morning with a new feature but can't figure out how to use it.
My Clock Faces feature says "We will automatically save up to 5 clock faces when you add them to your Fitbit so you can easily swish between them."
First :thanks for finally adding this feature!
Second: How do the watch face get added to My Clock Faces? I cant make them automatically save.
Thank you
2 REPLIES 2
If you go into the Fitbit app on your phone, then select clock faces, it will show you 5 spaces with a + in them.
click on the all clocks tab at the top and then search through and select the clock faces you want one by one ( the res select button) they will then save on to you phone app and Fitbit.
you will see that you have an new clock app on your Fitbit where your clock faces are saves, just scroll across to the one you 2amt to use at that time
hope this helps
Thank you Aitch115. It worked.
