05-16-2022
13:23
08:17
AndreaFitbit
05-16-2022
13:23
08:17
AndreaFitbit
Hi All,
I have a fit bit Versa 2 and the watch face isn't responding when pressing down on the face plate. This issue started, when I enable a pin because I was going to use the Versa for purchasing subway rides. Now, the face plate will not will not respond to to my swipes. Sometimes, if I really push down on the glass like I'm going to break it then once in awhile the I will be able to access the apps on watch. But most of the time nothing happens and on those rare occasions, I'm able to access the apps on the watch. I can swipe for days and the menus don't change. I have re-started the watch to no avail. Any ideas would be welcome.
05-16-2022 16:17 - edited 05-16-2022 16:21
Hello @mandb241
I understand you have already tried restarting your Fitbit Versa 2 and it didn’t resolve the issue. Before contacting Fitbit Customer Service look at this article I found here:https://smarthomestarter.com/why-is-my-fitbit-not-working-when-i-tap-it/
It contains some awesome troubleshooting tips. I’d also recommend if your using a third party watch try changing it back to the original clock face to see if that helps. Here’s how: open Fitbit app, tap profile picture, scroll down and tap Versa 2. Change your clock face here. Sync to accept the change.
😃Please let me know if the article answered your question and resolved the problem. Keep me updated…I’m crossing my fingers it helps.
05-24-2022 13:25
05-24-2022 13:25
No, this did not work. The face plate no longer work. I have factory re-set. Reinstalled the watch itself. It's just a worthless trinket now.
Best Answer05-24-2022 14:48
05-24-2022 14:48
@mandb241 I’d call Fitbit Customer Service: https://myhelp.fitbit.com/s/support?language=en_US They might be able to offer a possible solution
