05-23-2022
16:42
07:50
05-23-2022
16:42
07:50
Never had a problem with my Versa until yesterday when I received low battery indication. I put it on the charger and after a couple of minutes the Fitbit logo flashed on the screen. After about an hour I figured it was charger however it won't turn on?? The app shows last sync was yesterday at 6:38 pm and battery is at 17%. Charger is working fine as I tried my daughter's Versa and it charged fine.
Any help greatly appreciated. Thanks
05-24-2022 07:53 - edited 11-19-2023 02:54
Hi there, @Denise24. Thanks for stopping by in the Community Forums and already testing your charging cable. I understand where your concern is coming from.
As a first approach, please try restarting your Versa. For instruction, see How do I restart my Fitbit device?
If the restart doesn't work and you haven't felt a vibration on your watch during this process, I recommend trying the following steps:
Hope that helps.
05-24-2022 19:22
05-24-2022 19:22
Thanks for the suggestions unfortunately none worked. 🙂
