10-15-2021
18:25
08:38
10-15-2021
18:25
08:38
I have use different fitbit watches for many years. I am very disappointed with them. Everyone I owned all stopped working within 16 months. The last one I bought I got the warranty with it. I was charged $35 to replace it. I believe I was sent a refurbished one. Stopped working within a month. Sorry to say but I think I am going to look else where. It's sad because I do really like the watch but I would like something thats going to last longer. Specially for the price.
Best Answer10-16-2021 08:40 - edited 10-09-2024 08:22
Hi there, @Tpjohnson22. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa Lite. We‘re taking your comments and sentiments in regards to our products and services into consideration.
To better assist you with this, may I know the issues you're experiencing with your Versa Lite? Nevertheless, if you experience any of the following issues and you've checked your settings, restart your device:
Restarting your device turns it off and on without deleting any activity data. For more information, see How do I restart my Fitbit device?
Hope that helps.
Best Answer10-18-2021 07:26 - last edited on 10-22-2021 16:19 by LiliyaFitbit
Over the past 4 or 5 years I have had different fitbit, Blaze, versa 1,
versa 2, versa lite etc. Everyone only lasted about 14 to 18 months.
Screens had turned black on everyone. They all seemed to work, just the
display screen would stop working. Tried resetting them called customer
service with all of them but even they could not fix the issue. I have no
complaints with customer service. They were very nice. It just seems like
I have no luck with their product.
10-19-2021 05:42
10-19-2021 05:42
Screen is black and restarting it does not fix the issue.
Best Answer10-19-2021 06:25
10-19-2021 06:25
I also have the same problem. I got a fit bit versa in December. It died in June. Got a replacement and now that has died tonight. Both times the screen just stops working so I can see the time but that's it. I only realise it's happening cause my alarm goes off and I am not able to stop it.
Restarting the fitbit does not help.
What happens how I have already had a replacement?? This device has not even lasted a year. Very disappointed. T.I.A
