04-25-2018
15:13
17:05
EdsonFitbit
04-25-2018
15:13
17:05
EdsonFitbit
After my first charge the battery lasted over 4 days .....since then it has dropped to 24hrs only a charge. Not impressed.
Moderator edit: added label
Talk to customer service. I lose about 5% battery overnight and about 10-15% of battery during the day. That is with minimum notifications and all day syncing turned on. I am able to top off my battery while showering and getting ready for bed. This is the norm for battery life with average use.
Best AnswerI was really impressed initially.....but having altered nothing it’s losing over 75% in 24hrs. Which is poor in my opinion . I will monitor overnight tonight.
Thanks for the awesome help @Run_Epic! Nice to see you here @Uberdunk! If you are still experiencing a difficulty, I appreciate that you have shared your experience with Versa and for all the time and effort you have invested to solve this.
Please make sure that you have followed the tips and tricks provided in the help article Can I improve my Fitbit device's battery life?
Also, if you are using a 3rd party clock face switch it to an official Fitbit created clock face, 3rd party clock faces may drain the battery faster than the Fitbit ones.
Then, charge the battery to 100% (this process might take up to 2 hours) and don't charge until it fully drains. Once it's completely drained provide me with an update on how long the battery lasted.
Keep me posted!
Best AnswerI was having battery issues from the start. I called support and they told me to stop using a hub to charge my Versa and to plug directly into a computer to charge. This sounded very strange to me, but I had nothing to lose so I tried it. I went from having to charge daily to getting four days battery life as advertised. I still don't understand why it worked. So if anyone with battery issues is charging via a hub, try direct to a computer.
Best AnswerHi...i have fully charged it and worn with power consuming apps and functions switched off. ..fitbits own watch face and the device was completely drained of juice in 25hrs!!!
That is very poor! Is my unit faulty or are all Versas doing this?
I would also like to say that having to switch apps off, switch off power using functions, use fitbits own watch face is all a bit pointless futile if the device cant handle it. It's like telling customers the car you make can do 70mpg ...but only if the car is sitting on the back of a low loader!
The versa had already started to improve my fitness with the motivation it provides bug frankly mine is now unwearable as I can't be sure it's not going to go flat on me and leave me without a watch !!!
Awesome help @Dianna_AK! I appreciate that you have shared the troubleshooting tips that Support gave to improve your battery life. I hope you keep enjoying your Versa and it helps you to crush your fitness goals.
@Uberdunk Thanks for the reply! I wanted to thank you for all your time and patience with this. I wanted to assure you that we take into consideration all the comments provided by our users to continue improving your experience.
Upon checking with Support I was able to see that you have a case with them. I'm sure that they will help you to get back on track in no time. If you have further questions please let me know.
Catch you later! 🙂
