09-20-2019
17:48
12:18
DavideFitbit
09-20-2019
17:48
12:18
DavideFitbit
My Versa isn't giving me my notifications when I get text. I have deleted it and reinstalled it and it's still not working. Need help to get this fixed
09-20-2019 19:16
09-20-2019 19:16
Hi @KaMisha81 What phone are you using? Isnit on the Supported Devices List?
Try THIS Help Article on notification issues.
Helen | Western Australia
09-20-2019 20:11
09-20-2019 20:11
Samsung note 8
Best Answer09-20-2019 20:49
09-20-2019 20:49
Unfortunately that isnt a Supported phone, which could well be the problem. All you can do is try all the suggestions in the article I linked above.
09-21-2019 02:33
09-21-2019 02:33
Yes it is it worked before and I was getting all my notifications it just stopped working a couple days ago. I still get my calls and calendar notifications just not my text.
Best Answer09-21-2019 03:37
09-21-2019 03:37
The problem with unsupported phones, although they may work fine, is that when something changes (usually an update to phone or tracker), the connection can be lost, and as the phone is not supported, no one is working towards getting it going again.
09-21-2019 06:29
09-21-2019 06:29
I found another thread and got the issue fixed
