My Versa won't sync
Cant Sync my versa keep trying to Sync and wont connect. I'm holding my phone and wearing my Versa!!! I no longer cant get notifications on my Versa? What is happening? I know its charged and I'm within range? Is my Versa gone?
2 REPLIES 2
Hi, switch off your Versa by pressing the left and right lower button untill the Fitbit logo flashes and the watch turns off. Leave it of for a few minutes and switch it on again.If it still does not work, repeat this procedure. Hope this will work, if not you probably have to perform a factory reset.
Hey @DQ28, let me give you a warm welcome to the Community! If your Versa isn't syncing with your phone, I'd like to ask you this, what type of phone are you using? Is it a compatible device? In the meantime, try the troubleshooting in this help article: Why won't my Fitbit device sync?
Thanks for suggesting the restart @SunsetRunner!
I'll be around!
Heydy | Community Moderator, Fitbit
