09-02-2022
09:01
17:17
09-02-2022
09:01
17:17
I have been a loyal customer for many years now but I am so tired of these watches not lasting much more than a year. Just outside the warranty so I have to buy another one. I’m done. I’m switching. I can no longer keep putting money into these watches. Fitbit you need to have better quality.
Hi there, @Donewiththese. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3. We‘re taking your comments and sentiments in regards to our products and services into consideration.
To better assist you, may I know what is the issue you're experiencing with your Fitbit device? If you experience any of the following issues and you've checked your settings, restart your device:
For more information, see How do I restart my Fitbit device?
Best AnswerAt least two to three times a day I have to re-sync to my phone and once a week I have to completely reset it. It is unacceptable. I am tired of the constant issues. My last one stopped syncing right after my warranty was out. This one is on the way to doing the same thing. Poor quality products.
@Donewiththese Thanks for getting back and for the details provided. I understand how you must be feeling.
Based on what you mentioned, I was wondering if you are using the same mobile phone you used with the previous Fitbit device? If so, I'd suggest making sure that Fitbit device is not still linked to your phone's Bluetooth settings as this may be causing some connectivity issues with your Versa 3.
With the above being said, please try the following:
Hope this helps.
Best AnswerIt seems that many users (myself included) are having the same problems with the Versa 3. The official answer is "disconnect and reconnect" seriously?
I have done all of these over and over again. This is not the same phone that I had my previous watch connected to. I know all the steps as I have done these many times. Doesn’t matter. Still stops syncing many times a day. Not worth all the trouble.
Exactly. I get the same answer every time and then when those steps still doesn’t work they say “well you will have to buy a new one”. Not acceptable.
