I’m getting a new replacement Versa sent to me. How do I set this up. Do I start it up as I new device using the app and putting the watch on the charger ? Or is there something else I have to do ? Help
Hi, you would go into your app settings and remove the old Versa. Then, with the old one turned off, and the new one on, do add device in your app. When you do add device, the app will look for nearby trackers, and connect to the new one. I would have it in the charger to start off fully charged.
