05-11-2018 20:59
05-11-2018 20:59
I had a pebble and fitbit Alta. I thought the Versa would allow me to wear one only. Yes I wore both. I did the step by step from the book and app. I got text to be able to flash on my Versa but it would disappear after 2 seconds. When I try to pull text down it would say " You are up to date. No notifications". I am sick of battling with this for 4 hours, step by step. Can someone help?
Best Answer05-12-2018 13:33
05-12-2018 13:33
I'm having the same issue. if you don't catch the notification it acts like it as if it was never there. Did not have this issue before the update.
Best Answer02-14-2019 07:14
02-14-2019 07:14
did you continue to have issues with the banner notification disappearing after a second. just got mine yesterday and the call notifications work but the texts appear for what it feels like a second and then disappears adn tells me " You are up to date. No notifications"
