02-17-2019 21:51
02-17-2019 21:51
Hello, I just bought Fitbit Versa. I have OnePlus 2 mobile. I tried to sync with it but not working. When I purchased it was alwys showing Logo of fitbit. Then I start installation with some different mobile which has higher bluettoth version. Installation is successful. But then I tried to reconnect to my OnePlus 2 it have bluetooth 4.1 it is not synching. It is also not showing notifications of my mobile.I tried everyway mentioned on community forum..
Is it OnePlus 2 is not supported? It is not showing in compatible device list.
Best Answer02-17-2019 22:18
02-17-2019 22:18
Hi @bhangale.parag Unfortunately you are correct - the OnePlus 2 is not supported. The requirement is for Android OS 5 or higher, so I doubt you will get it to work. Do you have another device you could use, like a tablet or laptop?
Helen | Western Australia
02-17-2019 23:39
02-17-2019 23:39
I do have latop, tablet, I did started it with some other mobile which have higher bluetooth version.
But is it the case it wont work with my OnePlus 2 device?
