Best AnswerHi, @Lylitu, the Versa is definitely designed to be waterproof and used for swimming exactly as you have done. If yours seems to be suffering from water damage, then do get in touch with Fitbit Customer Support on contact.fitbit.com. If you contact them via email it can be helpful if you provide a photograph showing the damage/ issue, if possible.
Welcome to the forums!
Best AnswerHi, @GreginJaxFL, when you say your "first Versa" I guess that means that Fitbit replaced it for you? Is your second Versa working as exoected, including in the pool?
Thanks for commenting.
