Hello, I've been having a problem syncing with my fitbit versa 2 so I deleted the watch off of the app and then when I attempted to reconnect it it wouldn't recognize it and therefore I can not connect my fitbit to my phone if you have any suggestions please respond, thanks!
Hi @Ewonto , try this:
1. Remove the Fitbit app from your phone
2. Restart your phone without enabling BT. When it's automatically enabled, disable it.
3. Reinstall Fitbit app
4. Press add device and choose Versa 2
5. Let Fitbit find your Versa
6. Once found, Fitbit will tell you that BT is not enabled and if you will allow Fitbit to enable BT. Press yes.
7.Once found, sync your Versa 2 with your Fitbit app manually.
Good luck and regards kuzibri
