08-31-2019 01:29
08-31-2019 01:29
Hi I've recently updated to the new-look Fitbit app and since then I have lost notifications ability (Phone calls, sms, calendar, etc) on my Versa (first gen). I am currently running Android (Version 9) on my phone. In the Fitbit app under notifications it says, "Notifications not running. A phone restart is required...". Phone restarts do not change anything and I've tried deleting and reinstalling the Fitbit app.. Nothing it's working. Also tried a factory reset on my Versa. No change.
08-31-2019 01:32
08-31-2019 01:32
Correction on this post: My device is a Versa (1st Generation)
Best Answer08-31-2019 01:46
08-31-2019 01:46
Hi @Bske96, welcome to the community.
The only thing I can think of checking is the following -
In the settings app on your phone type in "notification access" in the search bar - tap on the result that comes up "notification access" - confirm the toggle is enabled for Fitbit.
Best Answer08-31-2019 03:47
08-31-2019 03:47
I have the same issue this morning. Never had it before.
It's not just you.
08-31-2019 03:48
08-31-2019 03:48
Checked and the toggle is enabled for Fitbit. It was working before.
Best Answer08-31-2019 04:07
08-31-2019 04:07
Have you tried clearing the cache for the fitbit app? Setting - Apps - Fitbit - Storage - clear cache.
08-31-2019 04:13
08-31-2019 04:13
hey thanks for the tip, I didn't try that yet. I just checked now and the toggle was set to "On".
Best Answer08-31-2019 05:11
08-31-2019 05:11
Clearing the (6mb) cache didn't work, though thanks for the suggestion. It has only been used for 3 days on this phone.
I get the same message on my old phone.
Best Answer08-31-2019 10:47
08-31-2019 10:47
Just a thought. Did you happen to try uninstall and reinstall the app?
My husband has the same issue with his Versa and a different phone. It's not a specific Versa or phone, it's more widespread.
Best Answer08-31-2019 10:58
08-31-2019 10:58
Another thread linked here about the same issue:
https://community.fitbit.com/t5/Versa-Smartwatches/Versa-won-t-receive-notifications/td-p/3704737
I have commented on there, as a Fitbit staff member has replied.
Best Answer08-31-2019 11:34
08-31-2019 11:34
Best Answer08-31-2019 16:24
08-31-2019 16:24
No one else has Galaxy Buds, do they? I do, just wondering....
