@JanetLim by reset you mean regular reboot (press and hold the left and bottom right buttons)? What's your phone model and OS? For now, please try this:
The trick here is to not pair in phone Bluetooth settings but rather let the Fitbit mobile app do that.
Additional tips if sync issues persist: If you have Wifi set up, go to Fitbit mobile app and remove it, then sync your Versa. I noticed that it causes issues for me. If you have other Bluetooth devices paired with your phone, forget them. One of them might be causing issues. Also, make sure All day sync is enabled. If you're on Android, make sure your Fitbit app is not being optimized by Android battery settings. Also on Android, make sure that Always Connected and Keep Alive Widget are enabled in the Fitbit app.
