08-03-2019
09:00
08:55
JuanJoFitbit
08-03-2019
09:00
08:55
JuanJoFitbit
The app keeps showing Notification service not running on my OnePlus6 phone.I have to cleare cache and storage and re-login back to the app to make it work.
Seems like the app is not stable.Dont expect this from such a high end and high priced device.Hoping to get an explanation on this.
08-05-2019 08:54
08-05-2019 08:54
@Clinton207 I'm sorry for the late response. However, I'd like to welcome you to our Fitbit Community.
Regarding the notifications issue that your Fitbit Versa is experiencing, I'd like you to try the troubleshooting steps that are listed in this help article. After this, monitor the notifications feature again and see if the issue gets fixed.
By the way, I appreciate the troubleshooting steps you tried before contacting our forums.
Keep me posted on the outcome! ![]()
Best Answer10-14-2019 23:11
10-14-2019 23:11
Hi, i am also using one plus 6 and not receiving any of the message notification except calls. Can you please provide a solution ASAP
Best Answer10-15-2019 06:43
10-15-2019 06:43
@1plus thank you for joining us in this thread and our Fitbit Community! Since your Versa is experiencing the same issue, I'd like you to try the troubleshooting seps that are listed in the help article that shared in my previous post.
After trying those steps, monitor your watch and see if the issue gets fixed.
Let me know how it goes! 😀
Best Answer10-15-2019 08:51
10-15-2019 08:51
Best Answer10-17-2019 09:38
10-17-2019 09:38
@1plus I'm sorry for the late response. However, I was able to get in touch with our Support team and was told that they assisted you via phone.
Our team is actively working on a fix to this issue and expect to have it resolved soon. Once a solution is available, we'll make sure to post it in the Community.
We appreciate your patience and understanding with this.
I'll be around if any question arises.
Best Answer10-17-2019 10:28
10-17-2019 10:28
I'm looking for a solution on this too...do keep me posted on the same ..
With the latest version of the app also the notification service gives an error and does not send notification after a bit.
Best Answer10-17-2019 10:38
10-17-2019 10:38
Try
1) Disable the battery optimization for the Fitbit app
2) Lock Fitbit app in multitasking switcher
3) Restart your OnePlus device
11-04-2019 02:31
11-04-2019 02:31
With the latest firmware upgrade to Versa (32.68.9.15) ..Some issues i'm facing
1.Messaging notifications are not working at all.
2.Calling notification stops working after losing some internet connectivity at times.
Question is is this expected?I mean i get that the app mght not sync due to network issues but i have to Re-install the app to make it work again as Clearing Data or Cache does not help ..
Been hoping for a resolution since July 2019. 😞
Note: The APP seems a bit heavy with the latest update but that is not a major concern..
Best Answer11-04-2019 02:32
11-04-2019 02:32
Thanks for the Suggestion..however the issue still exists..Does it work smooth with the OnePlus 7?
Tell me it does so i have some hope 🙂
Best Answer11-04-2019 04:06
11-04-2019 04:06
Yes, notifications are working flawlessly on my OnePlus 7 Pro for months (on Android 9 and currently on Android 10).
Best Answer11-04-2019 04:50
11-04-2019 04:50
Best Answer11-04-2019 04:56
11-04-2019 04:56
@Clinton207 no it does not work any better with the One Plus 7. It has the same issues you are having with the 6. Sorry for the bad news.
Best Answer11-04-2019 05:06
11-04-2019 05:06
As I wrote, I don't have any problem on OnePlus 7 Pro.
Best Answer11-06-2019 02:17
11-06-2019 02:17
@werionae Seems like the suggestion worked. I've been monitoring and looks like I'm getting notifications past couple of days.Thanks again 😎
What remains now is the Sync of the app.That works the first time but after sometime happens only if i re-install the app.@JuanJoFitbit Any pointers?
#Re-posting your suggestion 🙂
Try
Best Answer11-06-2019 02:55
11-06-2019 02:55
Best Answer11-06-2019 21:37
11-06-2019 21:37
Try this solution ..it should work as it's works for me (OnePlus6 User )
Also keep in mind ..Update the latest app & keep the 24hr time format on the phone..
