Best AnswerI use Samsung Galaxy and I've tried everything imaginable to get the versa to vibrate with notifications. Nothing worked!
Best AnswerHi, as I read in my email you marked it, accidentally, yourself as an accepted solution, so you also can undo this action. In your first post, press on the three dots and go to "this is not the solution" and press that. Problem solved. Good luck!!
