01-11-2019 11:33
01-11-2019 11:33
I have two notifications I can not clear from my versa Watch. All others can clear. I have synced several time and nothing changes. I have an iPhone.
01-11-2019 12:52 - edited 01-11-2019 12:56
Hi, try this:
Since your Versa does not delete your notifications, I would advice you to restart your watch and see if that solves your problem. Restarting is simple and can be done in two ways:
1. Go to settings, scroll down to Device Info, press that and scroll down untill you see: shutdown and press it. Once your watch has been shut down, wait for a short time and then press the home button (left one) to start your Versa again, or:
2. Press and hold the left and right lower buttons together and wait untill the Fitbit Logo appears on you display and release the buttons.
01-11-2019 12:35
01-11-2019 12:35
Mine been the same but my messages are from Wednesday only two messages that keep staying up and if you solve it can you let me know please
Best Answer01-11-2019 12:52 - edited 01-11-2019 12:56
Hi, try this:
01-11-2019 12:55
01-11-2019 12:55
Before I do this Will I lost my history?
Best Answer01-11-2019 12:58
01-11-2019 12:58
Of course not, it's not a factory reset, but just a restart of your Versa.
Best Answer01-11-2019 13:01
01-11-2019 13:01
Thank you so much it worked 😊 driving me mad it was 😂
Best Answer01-11-2019 13:07
01-11-2019 13:07
You're very welcome, that's why I'm around to help people with their Versa problems.
Best Answer01-11-2019 16:47
01-11-2019 16:47
@SunsetRunner,
Restarting did the trick!
Thank you!
01-12-2019 05:30
01-12-2019 05:30
That worked , thanks very much.
Best Answer01-13-2019 23:59
01-13-2019 23:59
Yes, THANK YOU. I’ve been trying to figure this out for a month.
Best Answer03-27-2019 09:12
03-27-2019 09:12
Omg it worked. I’d been trying to delete one message for 2 days. Thank you.
Best Answer12-06-2019 03:59
12-06-2019 03:59
Thank you SO much, kept tapping 'clear' and 'all clear' to no avail. Checked on line and thank goodness I found your post! Followed the easy instructions..YAY !!!
Best Answer01-30-2020 13:28
01-30-2020 13:28
Thank you. This worked.
