04-22-2018 15:58 - edited 07-30-2018 00:45
Wanting to buy the Fitbit Versa. However, I own a OnePlus 5t phone and this is not included in the list of Fitbit's devices.
How will this affect me when using my Fitbit? Will this prevent me from using all the services provided on the Fitbit Versa?
*Update* I bought the fitbit Versa and it works perfectly fine with my OnePlus 5t
04-23-2018 14:33
04-23-2018 14:33
OnePlus 5t user here with a Versa. No issues whatsoever. Not noticed anything untoward with syncing.
04-23-2018 03:28
04-23-2018 03:28
04-23-2018 04:10
04-23-2018 04:10
Thank you very much!
04-23-2018 04:19
04-23-2018 04:19
I have the OnePlus 3T and had issues with notifications at first and spoke to the Chat team who basically said Good luck due to a device that's not supported, they have the OnePlus One on the site under supported devices and the troubleshooting was the same as on the website.
I ended up factory resetting my watch and it's been good ever since apart from random notification blackouts as mentioned above.
Have fun!
04-23-2018 14:33
04-23-2018 14:33
04-24-2018 03:17
04-24-2018 03:17
I'm using the Fitbit versa with my Oneplus 5t and it's working fine, except for the connected GPS. My versa just keeps displaying 'connecting...'
05-09-2018 10:41
05-09-2018 10:41
Hi Adam!
I have a oneplus 5 and I am not managing to bring the screen to access the configuration of the Versa. When I link it to the Fitbit App and accept the Link, still doesn't work. Any advice on how you did it to link yours?
05-27-2018 17:38
05-27-2018 17:38
Hi Adam,
I'm having OnePlus 5T and my versa never syncs with my phone. i am unable to do firmware updates and my activities don't sync in bluetooth or WiFi. Could u please let me know what steps you did to sync if it is not too much work for you..
Thanks
Sandesh
06-01-2018 09:49
06-01-2018 09:49
Hi
I have a OnePlus 5 and I am planning to buy the Fitbit versa. I believe you also have the OnePlus 5. Can you please tell me whether it's compatible or not?
It will really help me decide
Thanks
06-01-2018 13:47
06-01-2018 13:47
Hi
I have a OnePlus 5 and I am planning to buy the Fitbit versa.. Can anyone please tell me whether it's compatible or not?
Thanks
06-22-2018 06:13
06-22-2018 06:13
My one plys 5 t is not compatible to versa , any one can help me ? I can’t sync my watch with mobile app .
06-22-2018 06:17
06-22-2018 06:17
06-22-2018 06:21
06-22-2018 06:21
Unable to pair my watch and mobile, versa not syncing with app . Unable to connect both
06-22-2018 06:22
06-22-2018 06:22
It’s working fine with iphone and google phone
06-22-2018 06:25
06-22-2018 06:25
06-22-2018 06:27
06-22-2018 06:27
Will try to delete app and reinstall again and let you know.
Thanks 🤞🏻
07-06-2018 23:35
07-06-2018 23:35
Hi Adam
thanks for your suggestions, it worked. Deleted other logins in nexus and 5T , re installed again app in 5T , wonder it worked. Wow now i can use my watch without using my phone in few cases 🤗👍🏻....
thanks again .
07-29-2018 22:39
07-29-2018 22:39
got any solution ...
want to buy Versa and I have 5t
07-29-2018 23:28
07-29-2018 23:28
07-30-2018 00:33
07-30-2018 00:33
I bought the Fitbit Versa, I had a lroblem with the screen about a month in to having it, but that was a problem with the Fitbit not my pgone.
Connections work perfectly and notifications work fine, so yes!
@shadowexplorer wrote:got any solution ...
