OnePlus 5t + Fitbit versa
ANSWERED
Wanting to buy the Fitbit Versa. However, I own a OnePlus 5t phone and this is not included in the list of Fitbit's devices.
How will this affect me when using my Fitbit? Will this prevent me from using all the services provided on the Fitbit Versa?
*Update* I bought the fitbit Versa and it works perfectly fine with my OnePlus 5t
1 BEST ANSWER
Accepted Solutions
OnePlus 5t user here with a Versa. No issues whatsoever. Not noticed anything untoward with syncing.
43 REPLIES 43
I've got the OnePlus 5 and it works fine with the Fitbit app. One thing I will say is that notifications can be a little glitchy, sometimes they stop working. I've found that the most reliable way is to enable the persistent sync service in the app. On the whole it works OK and doesn't drain the phone's battery.
Thank you very much!
I have the OnePlus 3T and had issues with notifications at first and spoke to the Chat team who basically said Good luck due to a device that's not supported, they have the OnePlus One on the site under supported devices and the troubleshooting was the same as on the website.
I ended up factory resetting my watch and it's been good ever since apart from random notification blackouts as mentioned above.
Have fun!
I'm using the Fitbit versa with my Oneplus 5t and it's working fine, except for the connected GPS. My versa just keeps displaying 'connecting...'
Hi Adam!
I have a oneplus 5 and I am not managing to bring the screen to access the configuration of the Versa. When I link it to the Fitbit App and accept the Link, still doesn't work. Any advice on how you did it to link yours?
Hi Adam,
I'm having OnePlus 5T and my versa never syncs with my phone. i am unable to do firmware updates and my activities don't sync in bluetooth or WiFi. Could u please let me know what steps you did to sync if it is not too much work for you..
Thanks
Sandesh
Hi
I have a OnePlus 5 and I am planning to buy the Fitbit versa. I believe you also have the OnePlus 5. Can you please tell me whether it's compatible or not?
It will really help me decide
Thanks
 Hi
I have a OnePlus 5 and I am planning to buy the Fitbit versa.. Can anyone please tell me whether it's compatible or not?
Thanks
My one plys 5 t is not compatible to versa , any one can help me ? I can’t sync my watch with mobile app .
When you say it's not compatible what issues are you facing? My Versa is
working well with my 5t.
Adam
Unable to pair my watch and mobile, versa not syncing with app . Unable to connect both
It’s working fine with iphone and google phone
Is your watch trying to sync with either the pixel or iPhone while you're
trying to sync it to the 5t?
Turn off the Bluetooth of both of these devices, delete your Fitbit app and
try again.
Will try to delete app and reinstall again and let you know.
Thanks 🤞🏻
Hi Adam
thanks for your suggestions, it worked. Deleted other logins in nexus and 5T , re installed again app in 5T , wonder it worked. Wow now i can use my watch without using  my phone in few cases  🤗👍🏻....
thanks again .
got any solution ...
want to buy Versa and I have 5t
Yes it works )
Sent from my iPhone
I bought the Fitbit Versa, I had a lroblem with the screen about a month in to having it, but that was a problem with the Fitbit not my pgone.
Connections work perfectly and notifications work fine, so yes!
