04-26-2018 06:21
04-26-2018 06:21
Why is it that when I start my Versa to track my ride its only measuring the duration of my ride and BPM.
The miles, MPH AVG and the MPH Max are all Zero. And yes, I have the gps setting on!!!
04-26-2018 22:50
04-26-2018 22:50
Same with mine, need distance please
04-27-2018 02:00
05-08-2018 14:35
05-08-2018 14:35
Mines doing this too. Did u find a way to fix it ?????
Best Answer05-08-2018 15:00 - edited 05-08-2018 15:01
I successfully tracked a bike ride on April 28, which included distance, mph, etc. However, since then it hasn't tracked those things. I'm not really sure if it's me, it's a temporary glitch, or if there is a bug.
05-08-2018 17:56
05-08-2018 17:56
My Versa tracked a bike ride really well today but it did not map the ride. Not really sure how to get it to do that.
Best Answer05-08-2018 20:05 - edited 05-08-2018 20:09
I was able to track a bike ride. . Versa tracked distance, time, mph, and heart rate. I had to take my S8 off battery save mode and all was splendid. It was a bit wonky when connected GPS was in power save on my phone.
05-08-2018 20:30
05-08-2018 20:30
Best Answer06-05-2018 15:52
06-05-2018 15:52
Same problem... My antique Surge worked perfectly?
06-06-2018 00:17
06-06-2018 00:17
It used to work when I just got it, but not anymore. I noticed that my Versa is not 'connecting' to the phone gps anymore after starting the 'Bike' exercise.
and yes I have been doing the standard stuff:
-turn off and on bluetooth
-turn off and on phone
-turn off and on watch
-reinstall app
-reconnect watch to app
Nothing helps
Best Answer06-06-2018 05:51
06-06-2018 05:51
Best Answer06-06-2018 05:55
06-06-2018 05:55
06-12-2018 16:55
06-12-2018 16:55
This was such a good tip! Thank you! Worked perfect after I shut my battery saver off 😊
Best Answer06-14-2018 10:34
06-14-2018 10:34
Do you have to have your phone with you? I biked last night and all it gave me was the time lapsed:(
Best Answer06-14-2018 15:59
06-14-2018 15:59
06-14-2018 15:59
I did have my phone with me
Best Answer06-23-2018 15:38
06-23-2018 15:38
Same problem - brand new Versa with spotty or non-existent outside bike tracking (connected to my iphone6)
My Charge 2 worked flawlessly
06-24-2018 16:16
06-24-2018 16:16
Just came back from a 27 mi ride - this time my Versa worked correctly! Don't know exactly why my first ride with the Versa looked messed up with spotty GPS/distance tracking.
My new Versa has been tracking treadmill runs/swims correctly, it was only the connected GPS that seemed to glitch.
Oh well, appears to be working now
Best Answer06-24-2018 20:04
06-24-2018 20:04
For versa to track mileage and speeds it needs to connect to your phone GPS. That happens if the bike exercise is tracked manually from the watch. Each time GPS connection is lost (battery saver, Versa having issues connecting to your phone etc.) speed and distance won't be measured. There will be no map either. Unfortunately due to the latest versa connection issues I haven't been able to track anything based on GPS.
06-25-2018 05:20
06-25-2018 05:20
Sometimes the GPS is still "connecting" and literally will say connecting on the Versa. Seems to be a problem with linkage of GPS and the Versa that is inconsistent as I've seen it in other forums and experience it as well. If you don't see the mileage number at the very top of the exercise screen, and it says connecting, that means GPS hasn't fully connected with. it is tracking but will not show the mileage etc. I usually have to cancel and restart. Happens more when I start the exercise indoors/garage vs once i'm outside with better signal. like I mentioned, it's inconsistent, but I have experienced this before too!
