05-13-2020 15:21
05-13-2020 15:21
I would be so grateful if one of Y'all would Help me Change this clockface back to the "Business" selection under the "Fitbit" group of choices--The one that's on now keeps messing up and it's driving me crazy........😭
05-13-2020 16:27
05-13-2020 16:27
To change your watch face, just remove the old one by clicking on it, scrolling to the bottom, and clicking remove, and then adding the new face.
Best Answer05-13-2020 17:15
05-13-2020 17:15
yeah, uummm.....my versa doesn't work that way as far as I can tell.....where's this 'remove' button?
Best Answer05-13-2020 17:53
05-13-2020 17:53
If you go on your fitbit app on your phone, tap your face, tap your watch picture and you will see clock faces. You will be able to change it from there. Good luck!
Best Answer05-13-2020 19:23
05-13-2020 19:23
yeah, the activity wheel just spins & spins & spins & spins.....🤢
