11-23-2019 17:28
11-23-2019 17:28
My bank card isn’t compatible with Versa so I don’t need a pass code. How do I remove the pass code from the Versa device?
11-23-2019 17:47
11-23-2019 17:47
Open the Fitbit app, account, your device, device lock. Disable pin code.
If you can not disable pin code, it should have been set for Fitbit Pay only and should not be a problem.
Let's look at the help doc, help link found below.
