11-13-2023 17:26
11-13-2023 17:26
I saw that the percent charged was being added back to the app, but not for Android. Is the plan to put it back and when. The change to remove it really irritated me. I am likely to replace my Fitbit soon, but will go elsewhere if this isn't addressed. After all, you removed this feature which I liked. Who knows what else you will do. What's the plan? When?
11-13-2023 20:24
11-13-2023 20:24
I have the same problem, I can't view the % charged, I have an android phone. I am definitely looking elsewhere probably Garmin, a friend has one and never had any issues with it. When the app was updated recently; it wouldn't sync with my watch. Customer support were useless, I worked it out myself, you can't have the app on 2 devices like before, so I deleted off my iPad and it started to Sync. I have numerous problems over the 10 years I have had a Fitbit, time to move on.
11-13-2023 20:31
11-13-2023 20:31
@Mikiwill1 I still have the app on 4 devices without an issue.
11-14-2023 08:54 - edited 11-14-2023 09:25
@EKN This is Fitbit's post on the topic -- Fitbit Community Blog It doesn't say that this is platform specific. I'm confident tht you will get this, too. Please share a link if you saw something that says it is iOS only.
Update: I just found this post in 9to5google. I use iOS and got the iOS v 4.04. Apparently Android version 4.04 isn't in the Google Play Store yet. The article mentions something about the Pixel watch, but that doesn't apply to Fitbit users.
Laurie | Maryland
