01-28-2019 18:46
01-28-2019 18:46
I play pickleball almost daily and was wondering if there was a recommended app or setting to record this exercise. So far, I have just been looking at the number of steps. When I first got my Versa last summer I looked for a pickleball-specific app, but only saw one for tennis which I couldn't get to work right.
01-28-2019
20:18
10:32
01-28-2019
20:18
10:32
Welcome to the forums!
Use Workout mode. Then set up a custom record for Pckleball. Once it syncs to the dashboard you can rename it.
Create a custom record is located at the bottom of the activity tracker
Looking forward to seeing you around the forums!
Wendy | CA | Moto G6 Android
Best Answer06-26-2020 16:12
06-26-2020 16:12
I have been playing for years and have recently decided that I would like to go pro once covid is lifted which is something I believe the Fitbit could really help me achieve. The people I have played are already largely Fitbit users over a variety of your products, there is also no technology that currently tracks pickleball stats. It would be incredible if the exercise mode could track the amount of meters ran, time, forehands, backhands, how many times I was at the net versus back, etc.
Best Answer04-14-2021 02:28
04-14-2021 02:28
Does the custom record you speak of create a new exercise option on the watch specific to Pickleball? If so, can you provide the instructions? Thanks
05:39
10:31
04-14-2021
05:39
10:31
@flroots Creating a custom workout doesn't add it to the exercise shortcuts on the watch. You can't add anything to that list. Creating a custom workout lets you rename an exercise after the fact. Creating a custom workout takes a few steps and it is done on your web dashboard. Here is how it is done:
When you play pickleball, use the Workout exercise shortcut. After you are done, go to those exercise details in your phone app. At the top, there is a Categorize Exercise choice. Type pickleball in the search field and it should be on your list.
Laurie | Maryland
