02-07-2021
		04:49
		06:36
			JuanJoFitbit
		02-07-2021
		04:49
		06:36
			JuanJoFitbit
When I swipe up on my versa 2 and get the today tab, I only have 2 notifications - steps and heart rate.
I used to get more on my versa se - including sleep data. When I go to settings there are only 3 options which are all ticked - activity, hourly steps and heart rate. How do I get more information please?
02-07-2021 07:21
                              02-07-2021 07:21
Swipe all the way up and tap Edit. Then choose the stats you want.
02-07-2021 13:08
02-07-2021 13:08
I only have 3 options there - activity, heart rate and steps. Nothing else to tick.
02-07-2021 22:01
02-07-2021 22:01
This is happening to me now after factory reset, I'm not getting heart rate data either. There is nothing else to add from Edit tab. I wish I hadn't done the reset, heart rate still not displaying. I just got this for Christmas.
02-08-2021 07:14
                              02-08-2021 07:14
I reread your OP you say that when you swipe up to get to the today screen.
To get to the today screen, the one I thought was being asked about, we would swipe left.
From the clock, when swipeing up, you will find the edit for this screen.
02-08-2021 07:37
02-08-2021 07:37
Actually, on my Versa 2 I swipe up to see that.
I responded to this via email not realizing it was a forum answer. I've been chatting with support over Twitter. After my last restart this morning, I have the option to add the normal things.
02-08-2021 13:17
02-08-2021 13:17
Me too, you used to get 7, including being able to add water. It's annoying as hell, especially as it states 7 options the fitbit basics part of the user guide. I had to do a factory reset (every time my phone gets a software update) and they had gone. So did another factory reset and set up, yep still gone, just the 3 options. I have sent a message via twitter, but I'm not holding my breath!
 Best Answer02-08-2021 13:19
02-08-2021 13:19
I don't get an edit screen when I do that. I get what the OP gets
 Best Answer02-08-2021 13:45
02-08-2021 13:45
Well, after 2 factory resets and reinstalls. Then several restarts and further uninstall and reinstalled app. They have returned.
This has taken a couple of hours that I will never get back!
 Best Answer02-08-2021 13:49
02-08-2021 13:49
I finally got my options back after a restart.
Still no heart rate data, unfortunately.
 Best Answer02-08-2021 14:01
02-08-2021 14:01
Oh no! The problem is we keep just doing all we can to "fix" their issue. Yours is a new device, personally I would return it.
I returned a Versa 3 that just kept unpairing and couldn't get GPS. Fortunately I still had the old Versa 2, which is generally OK, but I always have issues if I update my phone. Admittedly today's has been a particularly annoying issue.
But in your case, a fitbit without HR data, that's not good.
I hope you are able to resolve this.
