11-20-2019 06:04
11-20-2019 06:04
I just got a Versa 2, and I also have an Alta HR. The Alta is older and a little beat up, so I'd like to use it for sleeping and for work. Then I'd like to use the Versa 2 for pretty much everything else.
I've come across two problems so far. One, when the Alta HR was resting on my desk not in use, and I was using the Versa 2. The Alta tracked a sleeping period. This wasn't too bad, as I was able to just delete it from my sleep log.
But the second problem was more annoying. I left the Vera 2 on my desk and then wore the Alta HR to bed. Now I'm seeing that I got "basic sleep data" because Fitbit wasn't able to track a consistent HR. This is exactly what happens when I sometimes accidentally remove my Fitbit while asleep. I think it irritates me sometimes, so I take it off in my sleep. Anyway, to me it seems to have been tracking the Versa 2 on the desk, and not the HR I was actually wearing.
Sleep data is one of my most important features, so I was really hoping to get some help with this issue.
Thanks.
11-20-2019 13:25
11-20-2019 13:25
It normally will track the unit that sees the heart rate and sounds like there where times without an heart rate. Did you check the HR graph during the sleep period?
