Problems getting started with Versa
I can't get my Versa started.  App was downloaded on i pad, later i tried on i phone SE.  Both times app is okay but downloading doesn't get more than 12%.  The screen of the Versa gives still the message 'download the fitbit app to get started' and sometimes it changes into a blue line that starts 'growing from the left side' but it stops at 12% and then I get the message that there's no wifi or no bluetooth while there is one on the i pad of i phone.  I can't find any manuals or so to do this step by step - I'm not so used to downloading apps and all so I hope there is a simple solution for it !
4 REPLIES 4
Have you connected your Versa to your home wifi?
KC | Texas
One, Charge HR, Charge 2, Versa | Galaxy S9 Plus
Yes, on home WiFi but the uploading doesn't work and then I switch to Bluetooth, that works for a few minutes and then appears the red cross on the watch . All is okay on the I pad, both WiFi and Bluetooth connection but on the watch it isn't . It seems the WiFi and Bluetooth connection on my watch is not stable
Verstuurd vanaf mijn iPhone
Hi... have you resolve this issue.. i have the same problem here. Took me 2.5 hours to get to 20% with the blue line on screen then it stops. So frustrating
Hello,
I got in contact with Fitbit and after several things to try they have send me a new one.  This one works as how it should - so I'm happy no 🙂
Best is to get in contact with the help support of Fitbit.
