12-31-2019 16:40
12-31-2019 16:40
Where on the site can I purchase the extended Protection Plan?
12-31-2019 16:56
12-31-2019 16:56
Hello @Mhariton and a warm welcome. I recommend that you contact Support directly. The extended Protection Plan can be selected as you make your purchase from the Fitbit Store. I don't know of any way to add it on from the site after purchase.
Laurie | Maryland
Best Answer12-31-2019 17:04
12-31-2019 17:04
Note that you may see a one-time, temporary, offer in the Fitbit app to purchase the FPP within 30 days after you set up a new device.
There also was the choice to add this when purchasing through Fitbit.com.
If you don't get the above notice offering an extended warranty within a week of registering your Fitbit I see to choices.
Contact Fitbit and ask if it is possible, or contact Squaretrade. and add it through them.
