05-03-2018 06:45
05-03-2018 06:45
I noticed some time when I am viewing my Versa to check the time/heartbeat, there are two white dots above the heartbeat icon and at other times there isn't. Does anyone know what this means?
Best Answer05-03-2018 07:12
05-03-2018 07:12
It means you're in your fat burn zone.
05-03-2018 13:29
05-03-2018 13:29
As Shelly1011 said, it’s showing you’re in a fat burning zone, if it moved up to the second dot you would
be im cardio, and the third dot would be peak.
Best Answer05-03-2018 14:16
05-03-2018 14:16
@SunsetRunner @calumthomas Thank you both for your replies!
