Question about volume control
I plan on getting a Versa, and here is what I need to know. I will be loading my own music on the Versa, not using an app such as Pandora, etc. The bluetooth earphones that I currently use do NOT have volume controls of any kind. They simply pair to the device that is playing music (at this point, my iPhone), and you have to control the volume using iPhone itself. My question is, does Versa have its own volume control for music that is loaded directly onto it, or must your earphones/headphones have the ability for volume control? Thank you!
6 REPLIES 6
You can control volume from the watch...or the fitbit flyer have volume control
I use wireless earbuds on my Versa so again no volume buttons. But once you're in the music player app on the watch you use the two right hand buttons on the watch. The top one volume up the bottom button volume down. I am really impressed with how loud the music can get too. When I used my paired phone the music tended to be a lot quieter and too quiet in a noisy gym. The Versa is far better
Hope you can advise. I’m using my Apple AirPods with the Versa. Have had a medium volume only since buying two weeks ago, but put them on the other day for a run and was deafened/ had to quickly turn the volume down to a reasonable level. Now all I’m getting is a tiny amount of sound and they keep disconnecting. Any ideas?
Hi!! Can’t help you as I am experiencing the same volume issue.
have you found a solution yet???
Hi, and yes. The solution is a set of Taotronics Bluetooth earphones. Purchased these on amazon and they cost £18. Work perfectly and actually sound pretty amazing!!!!
Definitely worth a go and at that price you can’t lose.
Sent from my iPhone
I just got a versa 2 and I can't turn down the music sound. I am using the - button. Really loud
