05-11-2018 05:44
05-11-2018 05:44
Please enable it so that we can use quick replies with Textra! Quick replies are enabled on the notification shade on the phone, so I'm not sure why it won't work with the Versa.
01-27-2019 18:08
01-27-2019 18:08
Go to settings, customize notifications, define notification actions. There you should see android heads up. Hopefully that helps.
Best Answer11-12-2019 19:51
11-12-2019 19:51
Thank YOU.
Best Answer08-16-2021 19:11
08-16-2021 19:11
THANK YOU!!!!!!!!!!!!!!!!!! WORKS PERFECTLY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
