08-20-2018 18:53
08-20-2018 18:53
I have had the Versa for about 3 weeks. Set it up easily, but now the quick replies are not working. I get a message top check bluetooth connection and to make sure the phone is close. I've done all, but still can't regain use of my quick replies.
Any suggestions?
Best Answer08-20-2018 23:32
08-20-2018 23:32
Try restarting your versa a few times and uninstall the fitbit app on your phone, reinstall and log back in and try again. Let us know how you go
Helen | Western Australia
10-12-2018 23:29
10-12-2018 23:29
Had the same issue. I read on another thread if you are using the text plus app you need to open text plus and tell it to use quick replies in settings somewhere.
For me, I finally found the solution yesterday. I was using the fit notifications app with an older fitbit tgen by default with my new versa. A few weeks back something changed. I would only get open or dismiss as my choice. Removed fit notifications from my phone. I went into the fitbit notifications checked messages and WhatsApp. .... and guess what... WORKING AGAIN
i think the issue has become some of those 3rd party apps
