Quick view option isn't working
My Fitbit Quick view doesn't work. I have changed it in the app and on my PC but it still won't work. Any suggestions?
3 REPLIES 3
Have you got it enabled on the Versa? When on the clock press and hold the left hand button and you get 2 little vibrations. A screen then comes up swip till you get the one that says Screen Wake. There you can turn it from Auto (quick view) to manual. Let us know how you go
Community Council Member
Helen | Western Australia
It's great to see you here @Julie_H and @NellyG thanks for the input.
I would like to know if you keep having issues with your watch's quick view option? Have the instructions provided by our friend worked?
Hope to hear from you soon. Man Happy
I have the same issue with the Versa 2. In order to see the clock face I have to depress the button. That it is unsafe when I am trying to check my heart rate during exercise. I have ot turned on in the app.
