I just updated the Tracker software and after that I have had numerous problems... stops tracking steps randomly, won't hold the steps in memory, stops tracking BPM, touchscreen stops working, etc. It seems to fix the problems every time I reboot, but then it stops working again and I have to reboot. I haven't been able to show a full day of steps since I downloaded this most recent update. I have a feeling this is a bug in the latest software update. Anyone else??
Best Answer@tammyinca This sounds awful. I am afraid a regular reboot won't cut it at this point. You can attempt hard reset using buttons. Somehow I lost track which model of Versa you have 1 or 2, so I am posting steps for both:
For Versa 1:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
For Versa Lite and 2:
You can set up the watch back to the Fitbit account by following the instructions on this link: How do I set up my Fitbit device?
If you're not successful with the factory reset, I am afraid you will need to reach out to Customer Support to guide you through the next steps. Here's the link to Customer Support page.
Best AnswerHi @Marrrmaduke! Unfortunately, this morning, the touchscreen is no longer working and my Versa is definitely having issues. I turned it off last night hoping that would help, but the problems got worse when I took it off the charger this morning. Tried rebooting several times and still no luck.
So, I'm not sure how to check the firmware version because I can't scroll right to get to the settings icon? Is there a way to check that from my phone app? I use an iPhone 8 with iOS version 13.3.1. Does that help??
For Versa 1:
Best AnswerThanks @Marrrmaduke I appreciate the information. I have a Versa 1, so I will try factory reset instructions you gave below and see what happens. Hoping this fixes it!! 🤞 I will post whether or not it worked. Thanks again for taking the time to help others!!
Best AnswerI have been having these same issues and chatted with support. After 2 days and hours of trying they told me this was a known issue and they were working on it with no estimated time of when it will be fixed. That was on March 28th and I still have not seen an update or been able to get my Versa to work.
